03-11-2016 05:20 AM
I am using two y axis to show one is for voltage and other for current. I give a future to select voltage,currrent,or both. when user select voltage then second y axis should be disable. but for this one property node or terminal is needed there is no option of create when we click on y axis. please help how to do this?
Solved! Go to Solution.
03-11-2016 05:45 AM
03-11-2016 05:51 AM
hi GerdW,
Would you plz give the example of it.
03-11-2016 06:29 AM
03-12-2016 10:14 PM - edited 03-12-2016 10:16 PM
plz give the scrren short I am not able to find that property or is it same as Active Y Scale? if yes then I am passing 0 to it as its input datatype is numeric
03-13-2016 01:43 AM
03-13-2016 03:21 AM - edited 03-13-2016 03:38 AM
ok, but i want to hide it. please tell me how to hide it?
03-13-2016 04:30 AM
got the solution right click on graph->select create->property node->Active y scale->maker->visible
