graph setting color and scale
Im have a problem with this graph. I try to get the graph transparent and fit the x scale to fixed. But each time i re-iniciate the vi, it will be grey and auto scale X. How I can do it fixed ?.
Regards in advance. LV2013 file
Fred.
(2,763 Views)
Hi fonsi,
where do you set colors and x scale in your code?
When you do this using the brush tool in the FP you need to save your VI after customizing the graph…
(2,726 Views)
Hello GerdW,
Thanks for reply. Yes, I save the changes from brush tool palette, of course.
This vi is from biomedical toolkit in code it fits the colors when I try to put transparent I got grey again.
Regards.
(2,718 Views)
Hi Fonsi,
I don't use this toolkit…
What do you color transparent and becomes gray again? Have you tried to use property nodes to set colors?
(2,713 Views)
Check the picture attached. I want transparent the frontpanel of graph (lower graph).
Yes, i tried with property nodes but I didnt get.
Regards- Fred
(2,705 Views)
Hi Fonsi,
I never had problems to save a VI with a transparent graph. (I usually use classic controls in favor of the modern ones.)
Did you try the same with a fresh VI containing just the graph? Just as cross-check test?
(2,700 Views)
Yes, it works fine with normal vi, its in this case the 2 subvis in the main vi, fit it and i cant change it. I try to find to do it.
I attached the 2 subvi block diagram.
Regards.
(2,694 Views)
