06-20-2012 12:25 PM
Using LV7.0. Having a problem with a waveform graph. When I programmatically show and hide the multiple scales using the visible property, the scales do not re-appear where they are supposed to. I have to reset the scale layout to get them back to normal. Then, when I hide them and show them again, they have moved again. Sometimes, the background of the graph covers them (it doesn't resize properly) and other times the scale labels overlap each other. Has anyone had trouble with this and if so, how do you fix it? Thanks.
06-20-2012 06:27 PM
Opened with LV2010 and the problem is gone. I guess it was a bug with 7.0. I wrestled with that bug over and over throughout the years without a really good fix. Good riddance.
