05-24-2014 05:57 PM
All,
I have a large and, no doubt, inefficient image acquisition/processing VI running 2 Andor scientific cameras using their sdk package. Obviously, this is not NI-supported, but I have some weird behavior. Recently, I have found that several of the front panel indicators do not update unless I switch to the back panel and then back to the front panel. This is pretty obnoxious... any wisdom? Thanks. J
05-24-2014 08:47 PM
What is a "back panel"?
05-25-2014 10:12 AM
wiring diagram.... isn't that what we call it?
05-25-2014 10:26 AM - edited 05-25-2014 10:30 AM
We call it the "block diagram". 😄
Are there other operations that also restore the update (e.g. "minimize...restore").
Did it work correctly in the past? What changed (e.g. video driver update or similar).
05-25-2014 11:35 AM
Altenbach,
Whoopsie. As you can see, I have been doing more teaching and less research recently. I don't know that anything has changed (though there may have been a windows 7 update that installed in the night). Certainly, I have not installed any video drivers or new programs. Likewise, I am not sure when the last working version of the VI was. I wonder if the problem is not just my poor use of the Vision VIs creating a memory hog as these VI's seem to work much differently than the rest of Labview. I will check on the effect of minimization when I get back to my lab tomorrow. I do seem to recall that a hard stop (the stop sign button) leads to an update (and then 5 minutes of rebooting to unlock the PCI communication with the camera). Thanks for your time. J
05-25-2014 11:50 AM
For completeness, you should also tell us your LabVIEW version.
