graph - How to capture data from start to end
Hi Gerd,
I want the current time (the system time) on my graph(x axis). I want the system time to be synchronized with the readings. And I dont want all samples. Actually I will be adding a log loop later, which logs data every second. That's why I take average and get a single value every second. If I use waveforms, I will not be able to get the average.
Message 21 of 23
(490 Views)
Hi Gerd,
This vi too is not as what I wanted.
Help!
Message 22 of 23
(481 Views)
Hi kdm,
Help!
Don't you think you can try on your own before crying for help?
You should always state in clear and full description, what your goal is. When it's not what you wanted you can adapt it as you like…
I can display current (system) time nicely on a chart - when using waveforms as suggested before:
(I replaced your DAQmx stuff to create a working example VI…)
Message 23 of 23
(477 Views)
