01-28-2015 03:14 AM - edited 01-28-2015 03:27 AM
I have already installed the VI package manager. But I can't find the Express VI Structured Error Handler via Strg+space. Where can I find it?
I have the Labview Tools Network from JKI VIPM but when I search there for GXML which is required for the Error Handler it can not find it....
01-28-2015 03:54 AM
when I use clear errors, I need to build every time the .exe to check right? because generating reports is working in the development env. but not in the exe.
01-28-2015 06:31 AM
I asked NI to help me what's wrong with the .exe. I'm still waiting and will post the solution when I have it.
01-28-2015 07:40 AM
clear error function in the New Report.vi under NI_report.lvclass didn't work... the error is in the .exe still there.
02-02-2015 07:57 AM - edited 02-02-2015 07:57 AM
I got the solution from NI.
I need to create a new Virtual folder, add Folder (Snapshot) and there I must add the reports templates for Excel. The .exe wasn't able to access to these templates, therefore the error 7 has occured. When I build the application, I need to set this new folder as "always included" under "Source Files". In "Destinations" I need to add a new folder with the same name. Most important is that I enable the option "Preserve disk hierarchy" for this folder and "Set destination for all contained items" to this folder under "Source File Settings". Now it's working
02-02-2015 09:44 AM
Hey, thanks for the update, and BIG thanks for marking the problem as solved - AND for providing the solution. The reason why this is so important is that someone having similar issues in the future can benefit from your experience. 🙂
