01-21-2015 03:51 AM
we have two SCB connector blocks attached to analog to digital and didgital to analog NI DAQ cards 6133 and 6733 respectively.
a0 pin of connector block (NI 6733) is connected to the a0 pin of connector which is connected to NI 6133 card.
On both connector blocks the reading for the voltage is correct while measuring with multimeter but the VI is not geeting the correct voltage value in the indicator at front panel output.
attaching here the VI .
looking for help.
01-21-2015 07:01 AM
Did you connect the grounds?
01-21-2015 10:17 PM
yes. ground is connected.
