What NI device are you working with? If it is a newer card, it will be supported with NI-DAQmx, and
this post should help you out.
If you are using a device that is only supported with Traditional NI-DAQ, then
this post should help.
Once you have the correct libraries loaded, you should be able to
follow the same functions used in the text based example programs that
ship with the NI-DAQmx or Traditional NI-DAQ driver you have
installed. These examples can be installed and located as
per
this KB.
Let us know if you have more questions, and best of luck on the application.
Have a great day!
Travis W
Message Edited by Travis W on 10-11-2006 09:58 PM
