10-23-2014 06:10 AM
I have little experience with labview, my English is not very good, I'm new here, but if anyone can help I would be very grateful.
I am using DAQ 6008 to apply voltage and read. The analog input reads the signal all the time and sends the signal to a chart. This signal is a series of pulses, such as a square wave, but the voltage varies because it can be changed by the user.
I would like to read the signal from the chart every 1s, but when I put a numerical indicator instead of the chart, it only shows the first point on the graph.
Who can help, thank!
10-23-2014 06:58 AM
What value would you like from the chart? The chart has a lot of samples, but you only want to show one. If you just want the last value, just turn on the digital display for the chart (right-click on the chart, Visible Items->Digital Display).
10-23-2014 07:07 AM
firtst, thank you ;
so, In the chart I want to appear all points, but beyond that, I want to get a point on the graph in a second that I choose and show in an indicator, because I want to use this number to make a mathematical operation.
10-23-2014 07:11 AM
Correlating the time could be interesting, but you will have to get the chart history (with a property node) and then Index Array to get the point you want.
10-23-2014 08:26 AM
thank you!
but, how can I do this? I tried to convert to an array and then send for an array of values but could not, appears only the value of the first point
do you have any examples? which function I use?
10-23-2014 08:34 AM
10-23-2014 08:35 AM
here is the program that I did, I want to read the sign at the time the voltage is applied in "Tr" and get this value and use it to make an account...
