get one value from array pass it to board(H/W) then access the next value and pass it to the board
i want to access one value from the array then that value will be passed to a board, when the board finishes its processing then the next value from array should pass to the board and so on...this should be done automatically.
(2,115 Views)
Hi tanump,
at first you should go through those online LabVIEW courses available at www.ni.com, then you should use an autoindexing FOR loop...
(2,111 Views)
