get ip address of crio in network??
Hai,
I have few cRIO controllers in the network and need to get the ip address of those systems.  I tried using RT ping controller.vi but this vi takes a long time to respond.  How does MAX does it quickly??  Can any one help with api calls that max uses to detect the controllers both in subnet as well as out of subnet or is there any other way to get around.
Thanks for all help,
With best regards,
JK
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(2,841 Views)
JK,
simply decrease the timeout of the RT Ping Controller.vi
ThSa
(2,825 Views)
