05-11-2012 02:36 PM
@Charles K wrote:
LabVIEW 2011 has no support for SSL on Linux and Mac. Sorry.
What are the prospects for 2012?
05-11-2012 02:41 PM
Getting SSL support on Mac and Linux is something we care deeply about. Unfortunately, we are not allowed to talk about future releases.
08-13-2012 09:14 AM
Update: LabVIEW 2012 supports SSL for Mac and Linux.
08-13-2012 10:04 AM
Nice update. Brief, to the point, and exactly what we wanted to hear. 🙂
11-16-2012 02:33 PM
I am trying run to get_HTTP (Get.vi) on an RT target (cRIO-9014, LabVIEW 2011 version) to access a webpage on a Linux machine. I am getting the error as given below: (It works fine when I run this on my Windows machine).
Error 7 occurred at Call Library Function Node in LabVIEWHTTPClient.lvlib:GET.vi->get_HTTP.vi
Possible reason(s):
LabVIEW: File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS X, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
NI-488: Nonexistent GPIB interface.
HTTP client VIs (Get, Post, PUt , etc.) are supported on RT targets? Is there any workaround to fix this problem?
Appreciate your input......
11-16-2012 02:52 PM
Hi Vasudevks,
Can you start a new thread with this question? The issue you are reporting is actually different than what than the original at the beginning of thread. This will make it more searchable in the future.
Cheers!
Charles
11-16-2012 03:19 PM
sure....
06-27-2013 03:46 PM - edited 06-27-2013 03:48 PM
This workaround (adding the symlink to resource/ni_httpClient_nossl.framework in the LabVIEW 2010 folder) works fine for me in the LV2010 development system, but what about building executables for clients running Mac? I'm using LV2010 and I need to build a Mac application that uses HTTPClient VIs. Is this possible?
