generic error of labview 2011
Hello all!
I'd like to ask has anybody encountered the problem:  "generic error, Labview load error code 3: Could not load front panel"
in labview 2011. It is when I wanted to load a subvi into my main vi and it happened.
In the forum I see that someone got this problem when using labview 2009, and they were able to fix it
by installing a f3 patch. But for labview 2011 anyone got any idea?
thanks.
Chao
Message 1 of 10
(3,418 Views)
You VI is corrupted somehow..If you have backup then its good otherwise god bless you
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 10
(3,412 Views)
Well I guess so....and unfortunately I didn't back up...
Anyway thanks for replying, and I'd better post my vi here and see
if anyone got a way to open it.
Message 3 of 10
(3,408 Views)
there is no way..I faced this earlier
--Ranjeet
Message 4 of 10
(3,395 Views)
Accepted by topic author jcraffael
I was able to recover your VI: try to verify if it opens correctly also for you.
Bye!
Licia
Message 5 of 10
(3,370 Views)
Yes it is recovered and I can open it!
Thank you so much! But how did you make it? Any tips?
Message 6 of 10
(3,366 Views)
I'm glad the VI works also for you!
I had a look at the internal warning generated after trying to open the VI in updated versions of LabVIEW (where I got the same error as you) and was able to apply an internal procedure to fix the VI (which had a corrupt connector pane).
Bye!
Licia
Message 7 of 10
(3,362 Views)
Ah I see, seems a high level solution which I'm not able to handle.
Anyway thanks a lot for the effort!
Chao
Message 8 of 10
(3,360 Views)
What was the solution. How you fixed it?
It is very tricky error which caused by unknown reasong known to me....
Tell the procedure. It will be great help for others in future
--Ranjeet
Message 9 of 10
(3,356 Views)
Well the solution should be the second message of Licia instead the one which I marked as a solution.
As she said she applied an internal procedure to fix it, which remains unknown to me.
If possible I'd like to know it in detail, too.
Message 10 of 10
(3,351 Views)
