03-29-2015 11:04 PM
Hi everyone!
I just would like to ask a very BASIC question. I know some of you may find this easy.
Again, I am new in LabVIEW and I'm trying to use NI myDAQ as a data acquisition device. In the application I am trying to do, I need to get a pulse generating signal from myDAQ and use it as input to my multiplexer. I've been searching for the posts and i think none were asking this kind of simple question.
If there is any solution for this, please link it to me. THANK YOU VERY MUCH!
Falsehope
03-29-2015 11:31 PM
03-29-2015 11:44 PM
well sir, the multiplexer just need a Continous ON-OFF pulse so that it will switch from time to time depending on the frequency I will use.
So basically, I only need a basic clock output (about100kHz or lesser) from the myDAQ and the ON-OFF pulses will trigger the multiplexing capability of my device.
I need it to run in labview also. In such a way that the myDAQ is producing clock for the hardware and clock for the labVIEW.
But for now, my main concern is how do i prompt the myDAQ to produce clock pulses using LabVIEW softeare.
Thank you so much sir
Falsehope
03-30-2015 07:09 AM
The myDAQ has a single counter on it. You can configure the counter to output a frequency. According to the specification, the Frequency Output will come out of DIO 4.
03-30-2015 06:24 PM
03-30-2015 06:59 PM
@FalseHope wrote:
May i see a sample code of it?
Look in the Example Finder (Help->Find Examples). There should be something in there about a DAQmx counter.
03-31-2015 12:21 AM - edited 03-31-2015 12:21 AM
I'm afraid sir that I cannot do that. I am only using the Laboratory Computer of the School and it removed the examples folder of the LabVIEW (Maybe to prevent students from accessing the examples during hands-on exams). So yeah.. I'm a student with limited access to LabVIEW.
But I talked to the IT department of our school and it allowed me to download the examples instead. However, I cannot find available codes.
Falsehope
03-31-2015 07:32 AM
Falsehope
IMHO this is a dumb thing, a good teacher can easily create exercises and exam tasks to "measure" the real knowledge of the students, even if they use the built-in LabVIEW examples. A school should help during the learning curve, and not by disabling built-in examples, but by giving creative tasks...
I have attached an example VI, which will generate a 1 kHz counter output through DIO-3 and DGND. (I tested with a myDAQ device, it works)
04-03-2015 10:52 PM
THANK YOU SO MUCH SIR.
Dumb? TOTALLY DUMB. I'm telling you.
