generating a 1 bit bmp image
I have being trying to input an array and turn it to a 1 bit  bmp image.However, whatever the input, the generated bmp file is either all black or all white and I can't get the images supposed to be generated.
Can someone please show me how to fix that or provide any other way that can generate a "grayscale bmp image"?
I've been working on it but still not able to figure it out 😞
The attached file is the program I been working on.
Please help me! Any advice and suggestions will be greatly appreciated!!
Message 1 of 8
(3,656 Views)
Can you please post the VI in 2011 version.
Message 2 of 8
(3,646 Views)
one of the attached files is in 2011 ,and the other is in 8.0 version.
Thank you a lot!!!!
Message 3 of 8
(3,632 Views)
Hi Eya,
did you resolve the problem of saving bool bmp images?
I would like to generate bool image and your vi is really good for me but i have the same problem on saving.
If you have a solution i am really glad, thank you.
Message 4 of 8
(3,243 Views)
Add a Picture to Pixmap and use the Picture wire instead of the Image data and it'll work.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 8
(3,228 Views)
Accepted by wiebe@CARYA
Correction!
You need to supply the Color palette.
/Y
Qestit Systems
Message 6 of 8
(3,214 Views)
Thank you very much!!!!
Message 7 of 8
(3,198 Views)
I'll accept the solution, as OP is probably not going to.
Message 8 of 8
(3,187 Views)
