12-04-2013 04:34 AM
I have programmed VI to generate an analog signal(voltage), Now i have to generate a torque signal.
I'm using NI PCIe-6353..can anyone tel me how to do this ?..
12-04-2013 06:54 AM
torque is the tendency of a force to rotate an object about an axis.
Using a PCIe-6353 ... I can think about some mechanical setups 😄
SCNR
12-04-2013 09:46 PM
I use MTS 458 Controller..
In brief My system setup is like this my software(i.e, Labview program) will be interacting with MTS 407(this drives the Actuator) via DAQ NIPCIe-6353 card..
till now i have been generating voltage signal..now i need to send torque signal, i'm not much aware of this,whethe i need to have some voltage to torque conversion or labview has the torque kind of signal..to move further on my application i Just wanted to know these things..
12-05-2013 03:40 AM - edited 12-05-2013 03:42 AM
I don't think there even exists something like a "torque signal", correct me if I'm wrong.
Anyway, if you want to send a signal which pretends to be torque. You'll need to create your own transfer function.
This function will be different with different sensors, or in your case an actuator.
You'll need to check the manufacturers manual for this function, or create it yourself by trial and error.
12-05-2013 03:55 AM
Thanks A lot Koen,
that means 0 to 10 V voltage signal cannot be used or converted to torque to send itto my controller..
transfer function is the way to do this right
12-05-2013 04:00 AM - edited 12-05-2013 04:05 AM
Are you producing the 0 to 10V or are you measuring this?
If you are measuring it:
Build a transfer function for it using Expression node, then you can use this torque in program
Mostly the transfer function is the manual of the sensor.
If you are producing it:
You'll also have to build a transfer function but just before you send it.
The once you are producing mostly have to be made by a bit of trial and error.
EDIT: I added one function i use for the torque sensor, and one for output. Just to give you an idea
12-05-2013 04:41 AM
Thanks for ur info
I'm Generating a signal (0 to 10V Ful load torque) to the MTS Controller through the DAQ card (NI PCIe-6353)..
