09-03-2014 05:25 AM
Hi...I want to learn the basic designing procedure for Fuzzy logic system. I already go through the docs. I need basic fuzzy logic system. Could anyone help me with this....
09-03-2014 05:37 AM
10-24-2014 11:48 PM
08-03-2015 03:54 AM
I am doing my research in Static Excitation Systems of Synchronous Generator converting PI base system in to Fuzzy based Excitation system, i have prepared rules for fuzzy controller but for further implementation of model kindly guide or provide any related link.
02-14-2016 02:10 AM
Dear friends,
I am trying to implement a fuzzy logic controller. I built MISO type FLC. One input is set point which i will numerically control and the other input should be acquired as analog voltage signal value of my sensor which i acquired through DAQ. The output of the fuzzy controller is to be connected with DAQ and the value should be generated as voltage signal through DAQ.
I have two queries??
1. how to feed the acquired analog voltage signal value of sensor as one input to the fuzzy controller
2. how to generate the output of fuzzy controller as a voltage signal through DAQ
I hereby attached my .vi file. please go through it and give me an solution for this problem
thanks and regards
chandrasekar
09597748312
mds14m002@iiitdm.ac.in
