06-25-2014 09:02 AM
My function palette was moved on to a secondary monitor. I no longer have that monitor and cannot see the functions palette. I've gone in to the labview.ini file (in the Program Files/National Instruments/Labview 2011 directory) but cannot find an entry that sets the function palette position. I did see in another post that there was supposed to be such an entry for the tool palette, but can't find that either) How can I get the function palette back on screen?
06-25-2014 09:14 AM
Off-hand I'm not sure, but in the interim you can just right-click on the BD and pin the resulting palette. I think the old one will still be off screen, but at least you'll have something to work with.
06-25-2014 09:19 AM
Have you tried shutting off the secondary monitor in your video settings? That should force everything back to the primary.
06-25-2014 09:24 AM - edited 06-25-2014 09:27 AM
Close LabVIEW
Open LabVIEW.ini
Find this Line
saveFloaterLocations=True
Delete that line in your .ini, save the file, then relaunch LabVIEW. All better?
@Niquist- Oh Absolutely that is a true statement! unfortunately "Should" isn't "Does" (I'm pretty sure there is a CAR about that):smileywink:
