NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Active Participant
newbieeng
Accepted Solution
function palette not exact
hi all, my function palette seems different when I opened it by left-clicking on the block diagram window. I attached a print screen below. how could I correct it. it does not seem proper and have lost functions on it.
Egemen
Active Participant
EvenDeejay
Re: function palette not exact
Tools -> Advanced -> Edit Palette Set
You should be able to do some changes there:smileyhappy:
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Active Participant
newbieeng
thanks for your reply but I could not fix it by this way and I really do not know how to do it. Even I appylied the "restore default settings", it turns the same scheme.
Egemen
Knight of NI
It appears that some of your categories were set to be not visible. You can switch the palette view to "Category" and see which ones are set to be visible. This is saved in the labview.ini file with the key "PaletteHidddenFunctionlCategories".
Active Participant
newbieeng
thank you. this solved the problem. :smileyhappy:
Egemen
Active Participant
P@Anand
One more simple solution would be
  • Right click the block diagram
  • Pin the function palette
  • Click the Customize button
  • Select View this palette as>> Category Standard
You are done.
I don't believe in Hard work. I love my work :smileyhappy:
Active Participant
newbieeng
You are done.
I met up this problem when I click the right of the mouse. your method affects the main function palette.
Egemen
Active Participant
P@Anand
You are done.
Affects the main Function palette?. In which way ( I am just curious to know why this happens )
Active Participant
newbieeng
this way affects only the main function menu view. If you do not make all your functions visible, when you click right on the block diagram window it seems mostly empty.
Egemen
Active Participant
P@Anand
Yes you have to select the visible category in that. Is it coming empty even after doing this?
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
