front panel is fronzen in edit mode
I develop a vi in LV8.6
It's working properly.
i import it in Lv2010SP1 French and the front panel if frozen in edit mode.
i have open the diagram by code and, in the diagram i can work, but the front have no reaction !!!!
i can resize the front panel and the scroll bar change,
LV use no ressouce (processor : 0%, memory 400Mo > normal)
but in have no access to menu, object on panel, right clic, all is blocked. i don't can scroll or do anything
i have no idea and rewrite this VI is very long
it's a supervising vi with mani x-control
have anybody an idea to un froze the FP ?
nota : this vi is in a bigger application with dependcy, so it's not easy to send only the vi !!
tank's for all !!!!
EricC.
Ingénieur d'Application / Développeur LabVIEW Certifié (CLD)
Application Engineer / LabVIEW Certified Developer (CLD)
(1,934 Views)
And thank you for posting here,
Could you ckeck in your VI if you have any infinite loop in one of the Xcontrols? It seems that it could be the reason of the FP's freeze. You can also check if you have any property node which disables a Tab control.
It's probably one of these two reasons.
Please keep me posted. Regards,
Jérémy C.
NI France
(1,917 Views)
