07-17-2014 10:10 AM
I was just wondering about the persistence/volatility of the various memory methods after cycling power to LabVIEW FPGA Devices? Is it possible to ensure that data persists after cycling power?
Solved! Go to Solution.
07-17-2014 10:16 AM
07-17-2014 10:59 AM
Thank you for the quick response. Are we certain that _none_ of the memory techniques have persistence after cycling power?
07-17-2014 11:16 AM
There aren't that many memory techniques. You can store data on the FPGA either in logic gates, or in RAM. Both of those are volatile - they lose their contents when not powered. Some FPGA boards do have onboard non-volatile FLASH, but that is generally used to store a bitfile to be loaded on power-up. I do not know if it is possible for the FPGA to access the FLASH while running, but if it is you would need to write custom low-level (non-LabVIEW) code to do it, as there are no built-in functions that allow it.
