05-07-2015 10:30 AM
When I try to compile a FPGA vi, the following error occurs.
LabVIEW FPGA: The compilation failed due to a Xilinx error.
Details:
ERROR: [Synth 8-549] port width mismatch for port 'cEIOParameter0Signal': port width = 32, actual width = 24 [C:/NIFPGA/jobs/Riuys15_TD5ekmx/NiFpgaAG_0000051e_SequenceFrame.vhd:41]
ERROR: [Synth 8-285] failed synthesizing module 'NiFpgaAG_0000051e_SequenceFrame' [C:/NIFPGA/jobs/Riuys15_TD5ekmx/NiFpgaAG_0000051e_SequenceFrame.vhd:21]
ERROR: [Synth 8-285] failed synthesizing module 'NiFpgaAG_0000051d_CaseStructureFrame_0002' [C:/NIFPGA/jobs/Riuys15_TD5ekmx/NiFpgaAG_0000051d_CaseStructureFrame_0002.vhd:33]
ERROR: [Synth 8-285] failed synthesizing module 'NiFpgaAG_0000051a_SequenceFrame' [C:/NIFPGA/jobs/Riuys15_TD5ekmx/NiFpgaAG_0000051a_SequenceFrame.vhd:34]
ERROR: [Synth 8-285] failed synthesizing module 'NiFpgaAG_00000514_CaseStructureFrame_0001' [C:/NIFPGA/jobs/Riuys15_TD5ekmx/NiFpgaAG_00000514_CaseStructureFrame_0001.vhd:41]
ERROR: [Synth 8-285] failed synthesizing module 'NiFpgaAG_00000513_CaseStructureFrame_0000' [C:/NIFPGA/jobs/Riuys15_TD5ekmx/NiFpgaAG_00000513_CaseStructureFrame_0000.vhd:50]
ERROR: [Synth 8-285] failed synthesizing module 'NiFpgaAG_00000510_CaseStructureFrame_0000' [C:/NIFPGA/jobs/Riuys15_TD5ekmx/NiFpgaAG_00000510_CaseStructureFrame_0000.vhd:143]
ERROR: [Synth 8-285] failed synthesizing module 'NiFpgaAG_00000507_CaseStructureFrame_0001' [C:/NIFPGA/jobs/Riuys15_TD5ekmx/NiFpgaAG_00000507_CaseStructureFrame_0001.vhd:146]
ERROR: [Synth 8-285] failed synthesizing module 'NiFpgaAG_000004ff_WhileLoop' [C:/NIFPGA/jobs/Riuys15_TD5ekmx/NiFpgaAG_000004ff_WhileLoop.vhd:157]
ERROR: [Synth 8-285] failed synthesizing module 'DM_dash_1575_ModuleResource_vi_colon_Clone19' [C:/NIFPGA/jobs/Riuys15_TD5ekmx/DM_dash_1575_ModuleResource_vi_colon_Clone19.vhd:144]
ERROR: [Synth 8-285] failed synthesizing module 'niFpgaMDKSupportARV_vi_1_colon_Clone18' [C:/NIFPGA/jobs/Riuys15_TD5ekmx/niFpgaMDKSupportARV_vi_1_colon_Clone18.vhd:143]
ERROR: [Synth 8-285] failed synthesizing module 'NiFpgaAG_Manager' [C:/NIFPGA/jobs/Riuys15_TD5ekmx/NiFpgaAG_Manager.vhd:96]
ERROR: [Synth 8-285] failed synthesizing module 'TheWindow' [C:/NIFPGA/jobs/Riuys15_TD5ekmx/TheWindow.vhd:196]
ERROR: [Synth 8-285] failed synthesizing module 'toplevel_gen' [C:/NIFPGA/jobs/Riuys15_TD5ekmx/toplevel_gen.vhd:110]
Finished RTL Elaboration : Time (s): cpu = 00:00:53 ; elapsed = 00:01:04 . Memory (MB): peak = 861.121 ; gain = 715.336
ERROR: [Common 17-39] 'source' failed due to earlier errors.
INFO: [Common 17-83] Releasing license: Synthesis
1738 Infos, 30 Warnings, 2 Critical Warnings and 14 Errors encountered.
synth_design failed
::ERROR: [Common 17-39] 'source' failed due to earlier errors.
while executing
"source -notrace {./.Xil/Vivado-9588-/realtime\toplevel_gen.tcl}"
invoked from within
"synth_design -top "toplevel_gen" -part "xc7k70tfbg676-1" -flatten_hierarchy "full""
(file "C:/NIFPGA/jobs/Riuys15_TD5ekmx/synthesize.tcl" line 25)
invoked from within
"source "C:/NIFPGA/jobs/Riuys15_TD5ekmx/synthesize.tcl""
# exit
INFO: [Common 17-206] Exiting Vivado at Thu May 07 10:24:37 2015...
I am not sure what the error is all about. Could someone help me?
05-19-2015 01:12 AM
Use the NI Update Service to get the latest versions and patches.
All my compiler errors are gone with the latest C-Module driver update.
05-19-2015 07:41 AM
Thanks Christian for your reply. I changed the vi and created it from scratch. It compiled!!!. I am still unknown of the source of error. But anyway got it working.
Prabhu
05-19-2015 09:52 AM
It's usually better to take a look at where the code failed to compile in the process than trying to read through those logs. In future cases, you'll want to show that information as well.
Depending on your hardware, you might have been able to see the compile happen simply by hitting compile again.
10-24-2016 07:18 AM
Sometimes, it seems the code hasn't been updated. In my case, most of the times it is because my Custom module code was not updated properly by LV. Check for the new changes and see if they are updated properly.
