04-05-2012 10:09 AM - edited 04-05-2012 10:09 AM
I would like to use the FPGA on my 7811R to route a digital input directly to the PXI_Star line without any clocking. The signal I would like to route
is 25Mhz so would not be able to resample with conventional LV FPGA code. Is this possible? I was wondering if the IF-RIO async nodes would work
for this application.
04-05-2012 09:01 PM
simple answer, no you can not route directly.
you can try to use a derived clock to go faster, but this will still have some latency
05-05-2016 05:06 PM
Is there a technical reason why this isn't possible? It seems like you could probably lower energy consumption and minimize latency with asynchrous logic.
05-05-2016 06:04 PM
@igagne wrote:Is there a technical reason why this isn't possible? It seems like you could probably lower energy consumption and minimize latency with asynchrous logic.
The IO is hardwired to the FPGA. So the FPGA would have to read it and then pass on the signal to the PXI STAR.
