02-18-2014 02:35 PM
I'm getting this error when I try to run an FPGA program that has a target to host FIFO apart of it. It says unknown error and I can't find a topic online with this error explained. I've run the program before successfully but for some reason it is giving me errors now.
02-19-2014 09:59 AM
Hey apashl01,
Has anything changed in your hardware setup or LabVIEW project since the error started occuring? Can you connect to your cRIO in your project before you attempt to deploy your code? Have you upgraded your NI-RIO driver on your PC recently, but not upgraded it on your cRIO through MAX?
The more details that you can share, the quicker I'll be able to help you resolve this.
Ryan
02-19-2014 10:57 AM
02-20-2014 11:11 AM
Hey apashl01,
FPGA's cannot natively handle floating-point numbers like they can handle fixed-point values. It's possible that the way you were using the FIFO resulted in behavior that the FPGA could not handle with the floating-point value.
Ryan
02-20-2014 11:42 AM
Hi ApashI01,
I do want to clarify that LabVIEW FPGA does support floating-point numbers (SGL) in LabVIEW 2012 and later. Using the SGL data-type with DMA FIFOs is absolutely expected to work outside of Single-Cyle timed loops. Could you please post a sample project that reproduces this on your end? I'd like to do some investigation to get to the bottom of this seemingly erronious error message! Also, I'm curious to know what version of LabVIEW, and which version of the NI-RIO driver are you using?
02-20-2014 12:58 PM
Just FYI: Here's a very simple test to validate that both Target->Host and Host->Target DMA works for the SGL data-type.
