12-03-2009 10:38 AM
I am trying to use the formular node. There is a problem when I use the arithmetic shift right and shift left with formular node. The result show differently with using the labview code when the binary number length is 31. I attached the example. I need some one help explain what I am doing wrong. This problem also happen for orther operator such as "or, and" I am using labview 2009. the same thing also happen to LV 8.5
thanks
tphan
12-03-2009 10:42 AM
Can you upload into LabVIEW 8.0?
12-03-2009 11:13 AM
I don't have LV8.0 but I have LV 6.1.. Hope this works on LV8.0
Tphan
12-03-2009 11:20 AM
12-03-2009 11:37 AM
Hmm. I would say it getting worse in 8.5. Try this. It working in LV6.1 but not in LV8.5 . The formular mimics the rotation function in labview. All the input is int32.
Tphan
