07-07-2006 04:18 AM
07-07-2006 04:37 AM - edited 07-07-2006 04:37 AM
Message Edité par TiTou le 07-07-2006 11:37 AM
Epictetus
07-07-2006 04:45 AM
You have simpler options for doing this sort of operation
you dont need no formula node for that!
On block diagram First use 'greater than' function ( look in comparison tools), to find if input > 20. Next wire the boolean output to 's' input in 'select' function ( found in comparisons tools)
Wire a numeric constant '5' to input teminal named 't' in 'select' function
Wire a numeric constant '0' to input teminal named 'f' in 'select' function
If input 's' is true, select shall pass '5' in its output,If input 's' is false, select shall pass 'o' in its output
hope this helps.
How I wish that presently LabVIEW was installed on my system, so that i could have posted a snapshot of the block diagram
07-07-2006 04:48 AM
Ha!
TiTou beats me to that while I am typing the script!
Thats what I was trying to explain in words!
In LabVIEW, functions speak louder than mere words!
07-07-2006 04:57 AM
Epictetus
07-07-2006 05:12 AM
Aye to that!
cheers!
on the rocks!
07-07-2006 09:56 AM
07-07-2006 10:12 AM
Epictetus
07-10-2006 01:28 AM
