formating 8187 controller from host PC
If we format the controller (8187) from host PC . Does it formats everything including Ethernet driver and RT OS, LV RT, ? or there are some OS / drivers still reside after formatting the RT target.
Can I fresh install new drivers and RT version on this old controller or should we stick to use LV 7 and DAQmx 7 etc.
thanks
(2,081 Views)
thanks
I'm not sure what you mean by "format the controller".  If you "format your PC", you generally mean "format the hard drive that contains the OS", in which case everything is gone and you start over.  [In the case of multiple mis-steps, including installations of multiple LabVIEWs, this is often the best "Step 1"].  If you "format the controller", you probably are formatting the hard drive on the Controller, leaving it completely blank, able to do nothing until you re-install everything.
I would strongly recommend against installing LabVIEW 7 on this (relatively modern) Controller (we have a bunch of 8176 controllers, complete with floppy drives, that used to run LabVIEW 7 RT).  You can do so much more with "modern LabVIEW" (and DAQmx is so much easier than Legacy DAQ), including making intelligent use of the multiple cores on the RT side.
(2,042 Views)
