07-25-2008 12:30 AM
07-25-2008 01:18 AM
07-25-2008 01:29 AM
07-25-2008 03:15 AM
JB wrote:
Two ideas :
- 7/25/2007 ??? Is the time stamp input of the Format date/Time String function wired or unwired ? The date on your computer should be adjusted if unwired !
- You use only a one second resolution. Are you shure the delay between the multiple calls is longer ?
07-25-2008 03:41 AM
mathan a écrit:
For some reasons, the system year was set to 2007. The time stamp input was not wired. What to be wired to it?Delay between multiple calls is longer enough. 4 seconds. That's not a problem. What is that one second resolution? what it means?
07-25-2008 03:52 AM
The most likely option is that you have a bug in your code and you calling all of those within the same second. Without seeing the code there's no way to tell, so you should at least upload an image.
