flyback diode value for 12VDC, 12 Amp motor
Hello experts
I need help with deciding flyback diode ratings for use with 9477 module and 12V, 12Amp flowjet motor.
9477 manual says to use a flyback diode, but what rating and type will be sufficient, can any body give me some info,
how to calculate , any formula available?
Thanks in advance
(2,119 Views)
Try posting on a hardware board
http://forums.ni.com/t5/Motion-Control-and-Motor-Drives/bd-p/240
You are more likely to get a resolution
iTm - Senior Systems Engineer
uses: LABVIEW 2012 SP1 x86 on Windows 7 x64. cFP, cRIO, PXI-RT
(2,115 Views)
