11-24-2014 06:07 AM
sir i did the tast of float to bytes conversion using type cast in labview. now i also want that conversion using c code. means i want to know that how much labview can suport c code. farmula node is not suporting my code which is working wel in labwindows. kindly help me about that so that my skil can be improved using labview
Solved! Go to Solution.
11-24-2014 06:08 AM
11-24-2014 06:18 AM
ist kindly tel me that every work that we can do in c that work can be done in farmula node?
11-24-2014 06:19 AM - edited 11-24-2014 06:20 AM
Hi ranazee,
all the features supported by the formula node are listed in the LabVIEW help. What else do you need?
11-24-2014 06:48 AM - edited 11-24-2014 06:51 AM
can the code of float to bytes conversion can run in framula node in university we tried but not succedded
11-24-2014 07:32 AM
11-24-2014 08:52 AM - edited 11-24-2014 08:54 AM
The Formula Node as its name implies is for easy entry of algebraic formulas in text form and uses a C like syntax but is by no means a fully featured C parser/compiler. It only supports a subset of the C syntax for obvious reasons. Why would you need to implement fully fledged C code in a LabVIEW program since LabVIEW supports the same functions and in doing it with LabVIEW nodes you always will have better performance than you can get in the formula node.
If you have real C code you want to call in LabVIEW you don't use the formula node but create a DLL from it and call it through the Call Library Node.
