12-07-2005 04:49 AM
12-08-2005 03:27 PM
Greetings!
Thanks for the email. Please let me know if you are seeing any
specific issue designing your VI with the toolkit. Are you looking for VI with
that design specification you listed?
1) FIR filters provide phase linearity and the same goes with computation
speed.
2) The link below provides good information on DFD
http://www.ni.com/pdf/manuals/371353a.pdf
Thanks and hope this helps
Best regards
Avi Harjani
12-09-2005 06:01 AM
12-12-2005 02:14 AM
Basically, you can't use digital filter to replace analog filter if the input signal contains lots of noise.
So in your case, I suggest that you use a scc-LP(lowpass filter signal conditioning) before the daq and then acquire the singal using a low sampling rate. For example, you can use a 25Hz scc-lp and then a sampling rate larger than 50 (25X2)Hz.
Since you have a lower sampling rate, then your digital filter have a wider passband and a lower order.
12-12-2005 09:40 AM
