07-03-2014 12:42 PM
I am not sure if you are still active and I know this is a few years old, but I just found this and was wondering, how would I go about adding another set of cursors that do the same thing as the original two, but do it independently and calculate and independent average? I have been trying to perform this function for days but nothing works and I keep running into error.
07-03-2014 03:22 PM
It would seem trivial to extend my current code to many cursor pairs. Show us what you tried.
07-03-2014 03:51 PM
07-07-2014 08:29 AM
I am not at the lab right now and do not have access to it, but basically I used the property node to add two more cursors, and paralleled the indexes to that of the original two. Then I repeated the code from the original two cursors (that you wrote) for these two new cursors, in an indepedent while loop. I attempted to fix the problem by putting them into the same while loop, but that did not work either.
07-07-2014 10:14 AM
If my attachment above does not work for you, please show us your code. Most likely the fix will be very simple.
07-07-2014 10:16 AM
Your attachment worked perfectly! Thank you so much! Using this I can add to it to meet the specifications I have been given, so again, thanks for the help!
08-25-2020 10:18 AM
Hello, I have a vi that i am using to display the output of a strain gauge. There are two folders, the first is used to calibrate the gauge and the second to perform the test. Currently the average value is displayed at the end of the test, however i would like to be able to select the range to use for the calculation. I saw your solution using the cursor lines and tried to implement that into my vi but i could not get it to work (i have no experience with labview). Would it be possible to for you to take a look at what I have and see if you can help. thanks
08-26-2020 11:53 AM
Your VI does not contain any cursors. Show us what you tried. Were you using locked cursors?
(There are no "folders". Your VI uses 100% CPU when not doing anything and architecture seems inside-out. Have a look at a simple state machine architecture.)
08-26-2020 12:00 PM
Thanks for the quick response. I tried incorporating the code you created called GetCursor into my vi but I was unable to get it to work, I am very new to labview. I removed it because I didn't want to muddy the waters.
08-26-2020 12:22 PM
Then create a small VI only containing some typical calibration data and your xy graph.
