find the x and y coordinates closest to zero on a circle
Hi, I have a program that has created a 2D array that generates a circle. I need to find the index of the array that is closest to 0,0 (X,Y).
In the picture attached, I can see manually that the ellement I am looking for is 17 but I need labview to calculate the answer for me. Can anyone help?
(2,567 Views)
Accepted by topic author beam7
Fairly straightforward
Use X[] and Y[] as Real and Imaginary Rho is distance to origin.   find the minimum
"Should be" isn't "Is" -Jay
(2,552 Views)
Hi beam,
calculate the distance between your points and origin (0, 0). Find the minimum of all distances…
See this simple math on your array data:
(2,550 Views)
(2,539 Views)
Thanks GerdW
(2,536 Views)
