find a value in a boolean array
@altenbach wrote:
The sentence "find the only one that is true" implies that there is exactly one that is true, so finding it implies getting its index. We already know the value and that it xists exactly once.
The only complication would be in the case of higher dimensions, but he only gave a single number of elements, so it is probably 1D.
That might be true.  (Ha ha, see what I did there)
But how often do people on the forum make a suggestion with what is implied or assumed only to find out they were wrong?
Message 11 of 25
(3,026 Views)
@Neil_Helsel wrote:
I'm sorry it's a 2D array.
Ok wire the 2D boolean array directly to "boolean to 0,1" followed by "Array min&max". Then get the index of the max (second output from the top). The index is a 1D array with two elements and indicates the location of the TRUE in the 2D array.
If your array is aready numeric (0, or 1), yo can skip the first step.
Message 12 of 25
(3,017 Views)
It doesn't seem to want to wire to that. I'll include my code and another forum link to preface what the DAQmx is for. I'm sorry I'm new to LabVIEW and am not too familiar with it yet.
Background on the code
Message 13 of 25
(2,993 Views)
I don't see any arrays in the code you attached  above. I guess we need more information.
Message 14 of 25
(2,968 Views)
In Test 1(2) the Digital 1D Wfm looks like it sends out a boolean array.
Message 15 of 25
(2,950 Views)
Why do you attach two similarly named VIs with identical size. How do we know where to look?
You have a 1D array of digital waveforms. This has nothing to do with a 1D or 2D boolean array. However you could easily convert to a 2D boolean array, especially of all digital waveflorms have the same lenght (do they?). Use a simple autoidenxing FOR loop. See how far you get.
Message 16 of 25
(2,948 Views)
Okay gotcha. So with my 1D array of digital waveforms I have my index on the left column and T/F on the right. I'm trying to use search 1D array to find where it's T. I don't really understand how to use 1D array of digital waveforms constants though to make this happen.
Any tips on that?
Message 17 of 25
(2,933 Views)
@Neil_Helsel wrote:
Any tips on that?
You can always convert it to a boolean array and the use our earlier advice. Here's one possible solution using this function😞
(Sorry, I never use dynamic or waveform data. Maybe you could even configure your DAQ IO to output  boolean arrays directly. (I don't have DAQmx installed, so I cannot tell).
Message 18 of 25
(2,920 Views)
Are there any array functions that work with 1D arrays of digital waveforms, because non seem to like being wired to the 1D array of digital waveforms?
Message 19 of 25
(2,895 Views)
What's wrong with the FOR loop in my example?
(true we get too many dimension, but I cannot check what's actually happening.)
Message 20 of 25
(2,891 Views)
