Reply
filtre de signal par la fenêtre rectangulaire ou bien hanning
Salut,
je fait traitement de signal transmis par un échantillon  par labview mais je trouve que les signaux obtenu varient dans mon idée et de filtre mon signal par la fenêtre rectangulaire ou bien hanning
mon question comment filtre un signal par la fenêtre rectangulaire et hanning à partir de labview
le signal et un signal transmis des ondes ultrason dans un échantillon donc signal pas stationnaire
 merci
Message 1 of 4 (202 Views)
Reply
Re: filtre de signal par la fenêtre rectangulaire ou bien hanning
I tried running your question through google translate, and it didn't do too well. But it appears that you are using windowing on an ultrasonic signal before spectral analysis and are not seeing what you expect.
Remember that windowing is a trade-off. Applying a window to your data can allow you to resolve narrower spectral peaks, but it will distort the amplitude of those peaks. Using no window, or a rectangular window (which is really the same thing) does not distort amplitude but narrow peaks will tend to bleed together.
Hope this helps...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 4 (191 Views)
Reply
My question is
how to use the rectangular window and hanning filter for an ultrasonic signal in labview, sample program
thank you
Message 3 of 4 (171 Views)
Reply
You just wire the windowing VI into the array of time-domain data that you are passing to the frequency analysis code you are using.
Mike...
LabVIEW Champion
Message 4 of 4 (160 Views)
Reply
