04-24-2007 09:10 AM
Hello to all,
I would like to know why when I add these two signals (confer attached file) the resultant signal is not the one that I should have in the mathematical point of view. Cordially |
04-24-2007 09:16 AM
04-24-2007 09:23 AM
04-24-2007 09:27 AM
Sorry |
04-24-2007 09:32 AM
04-24-2007 09:43 AM
I am sorry but I added the attached file I don't know why it does not arrive. |
04-24-2007 10:13 AM
04-25-2007 07:34 AM
I sent my Vi exactly my signals have the same rate of samples. My wish is that the resultant signal is in form of stair, because he will allow me to load in constant voltage a battery.
For example
1,5v lasting 30mn
1,9 lasting 45 mn
But when the duration of cycle isn't the same I don't have a signal in form of stair.
Cordially. |
04-25-2007 08:21 AM
04-25-2007 08:56 AM
Thank you,
But I use "merge signal" for show on the same graphe the signals, but my wish is add this signals with "add" function (graphe4).And the result of this add isn't good, when the signals have different duration.I would like to know why. |
