01-12-2007 05:38 PM
01-15-2007 03:22 AM - edited 01-15-2007 03:22 AM
@Timothy 123 wrote:
I currently have a program in labview for parsing bit streams from a digital i/o board in a pxi chassis, but it is quite slow. Does anyone know if much higher performance can be gained by using cins or call function nodes and calling C code to do the bit stream parsing. And if so, which is faster.
-Tim
There is a lot to say about LabVIEW performance but most of it is not that LabVIEW is per se slow at all. The problem with programming in LabVIEW is that it is very versatile and quite simple to program and very easy to write vastly inefficient code if you do not think a bit before starting to draw wires. With traditional languages this problem is not as apparent since it is much harder to write a working algorithme unless you do some serious planning and thinking beforehand.
In most cases a LabVIEW algorithme can be made to be close to the performance you would get with a well implemented algorithme in C without using advanced C compiler optimization. An area where LabVIEW usually is a bit hard to program efficiently is with heavy bit manipulation. You can get surprising performance even there but the code does look sometimes not as simple as you sometimes have to do a few tricks to outsmart the automatic optimizer in LabVIEW.
Basically any algorithme that does rebuilding arrays in loops by appending or inserting data to the array is an implementation that will suffer performance in LabVIEW since LabVIEW uses completely dynamically allocated memory for all data. Most of these algorithmes can be made super fast by using the autoindexing feature on the border of LabVIEW loops. This is in fact the most common reason for performance complains, by using a Build Array or Concatenate String function inside a loop instead of autoindexing that array at the loop border.
As to the difference between CIN and DLL. There is basically no speed difference. A CIN is in fact a DLL too on Windows but one with a very specific exported interface. However CINs are legacy technology and there is a very big chance that as NI adds new platforms to the LabVIEW family the CIN mechanisme won't be ported to those platforms anymore. If you start programming external code now, use shared libraries. They are the prefered method for this, well supported and won't go away soon. CIN's are only useful if you have old projects that used them already and you need to upgrade to newer LabVIEW versions or platforms and even then I would highly advice to reconsider porting them to shared libraries instead.
Rolf Kalbermatter
Message Edited by rolfk on 01-15-2007 10:24 AM
01-15-2007 08:16 AM
01-15-2007 08:22 AM
@DFGray wrote:
There is an important performance difference between CINs and DLLs. CINs always execute in the UI thread. This means a swap to the UI thread whenever that code runs, usually slowing your program down. With DLLs, you have a choice. If your DLL is multithread safe, you can configure it to be reentrant and get a large performance boost.
That is not true! Adding an optional CINProperties() function with specific parameter handling you can tell LabVIEW that the CIN is reentrant and the CIN node icon will accordingly show light yellow. The difference is that here the CIN developer defines if it is reentrant (which is good since if someone should know it is the developer) where as for DLLs the person creating the VI has to know (or guess).
But that is still no good reason to use CINs. There is virtually nothing you can do with CINs that you can't do with shared libraries/DLLs but they are a lot easier to create, develop, debug and maintain in the long run.
Rolf Kalbermatter
01-17-2007 09:48 AM
01-17-2007 10:40 AM
01-17-2007 12:01 PM - edited 01-17-2007 12:01 PM
If you would give us an example of the parsing you need to do, maybe the collective brain of the forums will come up with a pore LabVIEW solution that is simpler and orders of magnitude faster. 😄
Message Edited by altenbach on 01-17-2007 10:01 AM
01-17-2007 01:39 PM
01-17-2007 01:50 PM
01-17-2007 02:08 PM - edited 01-17-2007 02:08 PM
Message Edited by Jarrod S. on 01-17-2007 02:08 PM
