02-12-2015 01:19 PM
hi all,
I use Labview 2011. I built one tdms file with hundred of groups. In each group, there are 25 properties values (date, temperature, time, etc...). I want to get 15 of the 25 properties for all the groups of this TDMS file. I used 'TDMS list content' function to get the names of each group and then I used the loop function and the 'TDMS get properties' to get the 15 properties. This solution is ver very very slow. I am pretty sure there is better solution. Any suggestion?
thank you for your help
Cédric
02-12-2015 03:13 PM
It sounds like you have a lot of data so you should expect it to be slow. But to try to speed it up you can defrag the file first.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
02-15-2015 08:15 PM
