06-19-2017 02:54 PM
Is there an easier way? Thanks!
06-19-2017 02:57 PM
No
06-19-2017 02:59 PM
Not even a "Reply hazy try again", huh? 😄
06-19-2017 03:19 PM
With 2017's type parsing palette it is theoretically possible to get array data and check that it has a type of "Cluster". And script out the vi's that get arrays of each single element. I wouldn't call that "Easier"
06-19-2017 08:45 PM
You might be interested in this idea: Why is there no function to reverse "Index & Bundle Cluster Array
06-19-2017 10:38 PM
That is pretty much exactly what I was asking about.
06-20-2017 04:10 PM - edited 06-20-2017 04:11 PM
Or using a VIM (2017) this would be possible, but you'd probably have to make a new VIM for each index in the cluster to pull out. Like a "Get Element 1 in Cluster.vim" "Get Element 2 in Cluster.vim" and then that would work changing the outputs based on the cluster type wired.
Also as mentioned in the idea exchange there is an XNode that does this over on LAVA.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
06-20-2017 09:37 PM
Hang tight. I may have missed a "outlook hazy try again later" response. But I stand by the NO for now.
