03-20-2012 07:06 AM
i am new user to vision & i am trying to extract ROI from an image. i made the code but not able to run it successfully. I am attaching my code. Please look at the code & suggest me the problem.
reply soon.
03-20-2012 07:08 AM
extract vi
03-20-2012 08:54 AM
Problems in your code:
a) race condition
b) wrong order
Andrey.
03-21-2012 12:00 AM
now i am able to run it.
thanks andrey.
10-17-2012 01:13 AM
Hi RV,
Your code is interesting.
I am attaching another code for extracting ROI from grayscale or RGB image. When i use the image in second attachment some it give invalid image. Not sure why. Could you figure out. Also, if you could see how can i "fit to window" in the ROI constrcutor pop up window since the image has to be scrolled due to its larger size. ..Thanks
05-13-2013 03:31 AM
related question:
how can i set the ROI tol be the entire image frame?
10-13-2013 06:50 AM
how can i select roi from entire image?
10-14-2013 05:07 AM
Just select rectangular ROI which will cover entire image (ROI's width and height should be equal to image's width and height)
