excel to graph with t0
Hi
I have a 2D array consisting of data recorded from multiple sensors and stored to and excel file along with the time of acquistion. The time period is constant. I need t0 to give to the build waveform function. how should i do it? I've tried using a few conversuions but all in vain.Im attahing the excel file from which i should be taking the time, t0
(2,103 Views)
I think you are looking for this.
Please note that in LV, the timestamp for a double value close to '0' (e.g. 1E-18) is 1AM on 1/1/1904.
Also, your graph element is configured to ignore timestamps (context menu!). You might want to change X-Axis labeling to display time only (not timestamp including date).
Norbert
Norbert
Expert: Geometry
(2,086 Views)
