07-03-2011 09:23 PM
When I use Excel Easy Table.vi to export my data, the double numeric values are losing precision. For example, 0.0054 to 0.005 and 0.0085 to 0.009. Is there anyway to stop this occurence?
Solved! Go to Solution.
07-03-2011 09:57 PM
what is excel easy table?
Could you please post the vi.
Regards
Grugh
07-03-2011 10:13 PM
It's part of the Report Generation Toolkit.
How are you converting to the string data that is the input? What format string? It's probably something as basic as using %.4f.
07-03-2011 10:27 PM
I have a 2D array of DBL data. The font (cluster in top left of picture) has no precision control.
07-03-2011 10:51 PM
Forgot you could wire numeric data directly to the fnction. Buried deep in one of the subVIs, the conversion to string is done. So, instead of modifying the subVI, just convert the 2D dbl to a 2D string array before passing it. Number to Fractional String will work.
07-03-2011 11:15 PM
Worked like a charm! Thank you.
08-05-2014 06:33 AM
Hi all,
how can i have access to the Vi ' excel the vi easy table' I use the LABVIEW 201 but can t find it.
best regdrs
Marcy
08-05-2014 08:00 AM
@marcy2014 wrote:
Hi all,
best regdrs
Marcy
Did you not read in the post above that it is part of the Report Generation Toolkit?
08-28-2014 09:45 AM
HI Guys
I get Labview Version 2014 but in my Report generation Toolkits i dont have : eXCEL easy Table. How can i get it please ?
Best regards
08-28-2014 10:16 AM - edited 08-28-2014 10:16 AM
@marcy2014 wrote:
HI Guys
Best regards
Report Generation Toolkit comes with LabVIEW 2014 Professional.
Otherwise you have to purchase it.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209050#functions
