02-27-2015 05:25 AM - edited 02-27-2015 05:26 AM
hi working on bringing exsiting code in to teststand with out editing the code to much, the code has a lot of event structers being set off by button change , while i have found away to change the state of the button while the code is running with out pushing the button the event structuer dose not seem to recagnise the change, and dose not do any thing, i have included a exaple of what im trying to do,
Solved! Go to Solution.
02-27-2015 05:58 AM
Local variable will not trigger event structures.
You need to use the "Value (Signalling)" property node.
02-27-2015 06:01 AM
thanks will give that a try
02-27-2015 06:23 AM
thanks that worked perfictaly still new to labview
02-27-2015 06:27 AM
No Problem.
It is worth having a read of the "Caveats and Recommendations when Using Events in LabVIEW" section of the LabVIEW help file.
