03-07-2010 06:15 AM
Hello.
In my main VI i have an event structure for few buttons. When I run the VI itself it works perfect.
When I open a new project, adding cRIO 9074 as a target, then adding the VI to the project the buttons doesn't respond. The event structure doesn't work.
Why? Is there any problem using event structure with RT targets?
03-07-2010 06:17 AM
Here is a little example:
03-07-2010 11:32 AM
Tacchi,
Front panel events do not work on RT targets. Only dynamic events are allowed on RT. The reason for this is that when a VI is running on RT, its front panel doesn't actually exist. See this KnowledgeBase for more info:
http://digital.ni.com/public.nsf/allkb/42B70D2D0C4B568586256E2F0051441D
Chris M
03-07-2010 04:07 PM
Hello.
I allready have read that.
So i tried to use dynamic events but it did work at all.
Maybe someone can show me a simple example, because all of the LV examples are pretty complicated.
Let's say i want a button that turn on a led when pressed, and off else.
03-08-2010 05:15 PM
Tacchi,
I'm going to have to side with CMal on this. Since the events being watched by an Event Structure are ultimately generated by the user interface, and the Front Panel is not downloaded to the Real Time target, you will not be able to use an Event Structure.
In this case, you may consider creating a second VI that can communicate to your RT VI through shared variables instead of using Front Panel or User Interface controls in the RT VI.
Logan H
