01-25-2015 03:39 AM
Why It will always stuck when i Combine the "add new user" Event to the "Login" Event ??
It work for me when i separate two but "add new user"button can run but only one time for the above structure,program will stuck on the second time i press the "add new user"button
Solved! Go to Solution.
01-25-2015 04:20 AM
Anyone?
01-25-2015 06:45 AM
01-25-2015 06:55 AM
When i combine the "add new user"event to the "login"event ,the whole front panal stuck when i pressed "add new user"button
why would it happen?
01-25-2015 07:42 AM
01-25-2015 07:56 AM
can u please hint me how should i suppose to do it ? im not sure where is wrong
01-25-2015 08:32 AM - edited 01-25-2015 08:36 AM
It was already told you, you should use only one Event structure and not 2. Also, avoid using local variables (better to store data in a shift register, and not in an indicator) how you do, it can cause nasty race conditions.
Actually here you just do not need other data storage since you have a file. Do not store data file in the root of the C drive, you may not have write permission. Use Default Data folder or the application folder.
I have attached a simple example. I guess this is a homework? Please make my help count: try to understand why your VI does not work, and try to find a solution by yourself. Modify my example, and play with it. This is how you can learn LabVIEW. If something is not clear, post here, and we can explain/help.
edit: at the "login" Event case, I do not check against whether the file exists or not. Fix this part, also gives some practice.
01-25-2015 08:51 AM
Thank you~
Im sorry bcos i dont understand just now...
Thanks for your sample
this is much appreciated.
01-25-2015 12:14 PM
If you don't understand the answer that was given, you're in WAY over your head and the example won't really help you too much. Instead of trying to push forward, take a few steps back. Learn about LabVIEW. Take free tutorials. THEN, try to do what you'd like to program.
