06-19-2014 01:55 PM
Hi mike,
In the NI website there are not a 2704 drivers. Only 24XX drivers
http://www.eurotherm.com/labview/
06-19-2014 02:25 PM
Give then a try, the low-level IO at least should work for you. Naturally, if there are higher-level VIs that refer to attributes that are specific to a particular model they won't be useful.
Mike...
06-19-2014 03:01 PM
ok thank you very much, tomorrow I 'would try to do it
06-19-2014 05:09 PM
@Dennis_Knutson wrote:
No, it's not universal at all. It is a requirement for GPIB instruments.
It's easy to get acronyms confused. You meant it was a SCPI command.
06-19-2014 05:14 PM
I think I'm wrong, too. I think it goes back even forther than SCPI, but I forget what it's called.
06-19-2014 05:49 PM
06-19-2014 06:06 PM
iEEE-488.2
And since that is the GPIB standard, it turns out that you were right and I was wrong after all.
06-19-2014 07:22 PM
06-19-2014 07:48 PM
Oh, and thanks for being so gracious and letting me down so gently. 😉
06-23-2014 03:49 AM
Thanks i resolved the problem by using 32XX series drivers download in NI site
