01-03-2006 11:38 PM
01-04-2006 12:30 AM
Hi Jimmy,
The simple answer to "1:" is don't use a loop - use a different "Set Control Value" for every input parameter.
Easier might be to bundle all the values in a Cluster - and pass one cluster instead of multiple values,
However, check-out the "Dynamic Load Example.vi" (in Examples) which uses "Call by reference node" - which is a really "Clean"
cheers!
01-04-2006 09:23 PM
01-04-2006 10:36 PM - edited 01-04-2006 10:36 PM
i would like to convert string value to fit any type value. But it looks impossible, because i only can pass one type value to control.Best regards,Jimmy
Message Edited by Dynamik on 01-04-2006 10:38 PM
01-04-2006 11:32 PM
Hi Dynamik,
it is heared that it is a great idea to convert input string value into cluster, but I don't how to complete.
Could you attach the program to my reference? thanks!
01-04-2006 11:40 PM
Hi Jimmy,
Please supply an example of the text file - that I can better help you.
