05-23-2016 08:39 AM
What is the oscilloscope model? Tektronix what? Give some more spec please.
05-23-2016 08:42 AM
for time , I want carried out measurements on two hours about my current problem
is to make a record each time a click appears and then have a report of all these clicks
Here is a more complete example of the kind of app that I want ::
05-23-2016 08:45 AM
@Blokk wrote:What is the oscilloscope model? Tektronix what? Give some more spec please.
Did you read it? What is the model you use? 🙂
05-23-2016 08:45 AM
05-23-2016 08:51 AM
Still kind of blurry, so I can just offer some general advice, since I'm working on something similar. From the looks of it, it seems like you're measuring all the time, and want to save data to a non-volatile log when a certain event occurs, so your best bet is a polling producer-consumer architecture and a FIFO style buffer. Basically you store data in whatever size you need for your purposes (for example, last 10,000 samples) in an array, cluster or whatever, then when the event occurs, you save that buffer to a report.
05-23-2016 08:52 AM - edited 05-23-2016 08:56 AM
There is a LabVIEW driver for this oscilloscope. First I would install this driver. Do it in this way:
edit: After your driver is installed, have a look what kind of DAQ options are available. Also have a look at the previous post from Daikataro, it gives you a possible way how to deal with the incoming data. You should have a Producer and a Consumer while loop. You enqueue the data arrays in the Producer, and then Examine the data in the Consumer loop. If you find a pattern, you can save the data to file.
05-23-2016 08:56 AM
YES Exactly, that is Some Kind What I want how to do ???
05-23-2016 08:57 AM
DAIKATARO , YES Exactly, that is Some Kind What I want
how to do ???
05-23-2016 09:00 AM
Check this example on producer-consumer architecture, pretty well explained and it can help you.
05-23-2016 09:01 AM - edited 05-23-2016 09:04 AM
What you want to do is not really a basic LabVIEW programming. At least you should learn first the basics. The other way is to pay a programmer or if you are lucky, someone will program it for you 🙂
edit: is this a school project?
