08-22-2008 01:28 AM
Hi there,
I get some error message while running my vi.
Possible reason(s):
LabVIEW: File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
NI-488: Nonexistent GPIB interface.
Has anyone know what the problem?I have check my file path and it is correct.
08-22-2008 02:00 AM
Hi gdah,
what do you make in your vi? Which function do you use? How do you check the file path? Use the "Not a path" function to see how LabVIEW interpret your path.
Mike
08-22-2008 02:10 AM
09-15-2009 01:42 PM
I am getting this same error message...I get it when I call any of the GPIB functions -> GPIB Write, GPIB Read, etc.
I also got this error the first time I used the "Open File+.vi" on a new install, but the SubVI only needed to be relinked - problem solved. The only problem here is, these are GPIB functions, not VIs, so there is no relinking option.
I tried a Mass Compile of the vi.lib and the instr.lib directories, assuming that these functions resided somewhere in there. No success.
Please help.
09-15-2009 02:00 PM
Error 7 for GPIB has nothing to do with your Open File problem or solution.
What kind of GPIB card are you using and what driver version do you have installed. Is the card listed in MAX and did it pass all of the diagnostics?
09-15-2009 02:07 PM
What is Error 7?
I was simply stating that I incurred this error twice. Once was the first time I called "Open File+.vi" - I was able to find this vi, open it, and and run the top level vi just fine - it just needed to be relinked.
The GPIB issue is something I am confused about, but yes, obviously not the same problem, since these are not VIs, they are functions.
I am using an Agilent 82357B USB to GPIB adapter, and I can see my instruments in MAX just fine.
09-15-2009 02:08 PM
09-15-2009 02:13 PM
09-15-2009 02:14 PM
I am trying to write drivers for instrumentation, and the very first time I try to communicate at all via these GPIB functions, I see this error.
I experimented a little. It doesn't matter what I'm doing (reading, writing, etc.).
Obviously I am not familiar with this error, but it appears that the GPIB functions of can't be found on the hard drive, which begs the questions, how are they on the functions pallette then???
09-15-2009 02:16 PM
Interesting. There is no way around this??
I will have to rewite everything using VISA functions?
