07-23-2014 08:04 AM
I have problem in logging data into a file.
File error says that the file is not valid, but there is a valid path and file.
Please help.
07-23-2014 08:07 AM
Show us your code, it is hard to find what is the cause without seeing the block diagram
07-23-2014 08:08 AM
Here is my code.
07-23-2014 08:17 AM
What part of your code is throwing the error?
07-23-2014 08:31 AM
I figured it out
07-23-2014 08:33 AM
Care to explain what was happening so that other people can learn from your experience?
07-23-2014 09:02 AM
Its not logging again!
This time no error but not logging.
07-23-2014 09:38 AM
You could be logging only on the first 4 iterations of your loop. Was the intent to log every 4 samples? If so, then you need to use the Remainder, not the Quotient, of the Quotient & Remainder function.
